Not starting up
29 Dec 2004
Chatham, Kent
Got a jetway ma3-79gdg motherboard that i took the cpu out of yesterday to give it a fresh coat of thermal paste. Maybe i put too much on? But this shouldn't effect this.
Upon connecting the ATX24 pin and 4 pin (into 8 pin socket so 4 are still exposed) and placing the CPU into the motherboard and fixing the heatsink into place. I proceed to press the power button.
the PSU spins up, the CPU fan spins up a bit then stops, then spins a bit more.
On the screen - Nothing, not even POST.
Any ideas?
Andy
Re-check all connections - i realise you probably have but do it anyway as it's really easy to overlook.
It may be shorting - check that the motherboard is securley fitted and has not become lose on the spacers - it's not uncommon for the screws to become lose over time and the motherboard to start moving about slightly. If it has, reposition the MB and re-tighten the screws.
If you don't have any luck with the above strip the rig down to a skeleton setup - cpu, memory, gfx - everything else disconnected and see if it boots up. If it does start attaching things until it buckles...
If that doesn't work i would rebuild the rig outside the case - but try the above first and see waht happens
Forgot to mention it's sitting on it's box so shouldn't be shorting on anything lol
Still not sure why the fan is reacting like it is. It's struggling to spin.
Andy
Have you tried unplugging the memory to see if you get any error beeps?
How old is the PSU - it may be worth testing another just to rule it out?
If you've tried all of the above and you're still getting the same result I would start giving the motherboard some very hard stares.
Did you try a different kettle cable when you tried the diff PSU?
Also is the PC plugged directly into a wall socket rather than an extension lead?
I'm sure MB or CPU designers hide an algorithm somewhere which randomly instructs the computer to 'now play dead and confuse the s*** out of the owner for a few hrs'.
Glad it’s magically come back to life – I’ve experienced a few of those ‘Lazarus’ moments myself. And agreed – they’re odd - but always greatly appreciated.
