Not sure how to connect RGB AIO cooler to motherboard
21 Sep 2011
Hi,
Looking for some help please:D
I am not sure how to connect my AIO IDCooling FX360 (link to short youtube vid here) to my Gigabyte X570 AORUS Elite motherboard(spec etc here, pdf here). Having read the manual and watched the vids I am still not sure what goes where and i dont want to fry anything? There are 2 connections from both the pump and the fans, as far as I can tell I connect my pump to cpu_opt and the fans to cpu_fan but I wasn't sure where to plug in the other connections, which I am guesssing are the rgb components? I have a DLED1 and LEDC1 and a D_LED2 and LED_C2, which i think are involved but wasn't sure which to use. Any help or advice would be much appreciated, thanks:)
ARGB is 5v and RGB is 12v, which I believe correspond as follows to your manual:
DLED = 5v ARGB (3 pin)
LED = 12v RGB (4 pin)
From what I can gather your cooler is an ARGB cooler?
Yes that is correct, as far as I know it is. ( the whole rgb argb confuses me:confused:) This is the cooler here
Thank you very much for your help:D
