Not sure if Orthos is worng or my overclock
5 Sep 2007
I’ve been trying to establish whether my overclock is 100% stable and have run Orthos for 18+ hours in each Small FFts, Large in place FFts and in blend mode all with out problems. Just for the ultimate test I tried running them all together by running 3x Orthos and it failed in the Large in place FFTs after 8 and a half hours on one of the cores.
Does this mean my system is not stable or was it an error caused by the way I was using Orthos?
I reckon that it's not stable. Orthos can only stress one core at a time. You've got two. when you start stressing both at once you will end up with more heat that either one of them alone.
No, I'm not. It looks like there are multithreaded versions out and others that don't make it clear either way. Suffice it to say the program is probably not erroring. You're putting more stress on your rig and it's failing because of it.
