- 14 Nov 2003
Apologies in advance for the longish post...but....
Got an Asus a8nsli deluxe mobo, Opty 170, Hiper 500W PSU, radeon 4850, asus xonar dx , 2 Maxtors 160GB in RAID 0 and 1 WD raptor as boot drive (plus a couple of optical drives).
System is a bit over 5 years old (with the exception of the Radeon which I got about a year back )..
recently moved house so the PC was switched off for a couple of weeks... connected it up and switched it on and started having freezes after a few minutes..
one of the error messages was the the H: drive (RAID 0) was not readable.. so I disconnected one drive and switched it back on, worked fine for about half an hour then same problem...
tried reconnecting other drive and disconnecting this one but other drive seems to be dead (doesn't turn on)... so it seems I only have one working drive from the RAID 0 config and that too fails after every half hour or so (but works once I reboot)
I checked to see any loose cabling etc but didn't note anything..however touched the top of the HDD and got a mild shock!... it seems current is flowing along the top of one of the RAID HDDs (but not the other), though this one works!...
no idea whats going on with the system...
the main boot HDD works fine...
I seem to have limited use of the PC's USB ports since if I connect more than a couple of external HDDs (by USB), one of them usually fails/powers down...
Any idea of why the RAID drives failed (ing) i.e. one seems totally dead and the current issue etc?
thanks!
thanks!
