So I was happily using my computer till my XFX750 PSU started making clicking noises and then went !POP!
This leaves me in a dilemma and I am not sure what to do for replacement parts.
After several days of testing I have identified that that the PSU also killed the motherboard & CPU too which makes things expensive!
So I currently have these working parts available
Case: Phanteks enthoo primo
Ram: Avexier DDR3 (16GB Dual Channel)
CPU: I have a spare i5 Haswell CPU
GPU: EVGA 980Ti
WC: Full dual rad loop
I was holding out for the new x99 @ Q4 2016 to do a major upgrade BUT now this has happened I am not sure which of the following to do.
1) Just get a cheap Haswell motherboard and still wait Q4 2016
2) Just buy into the x99 board even though its at EOL for CPU upgrades
3) Go for a Skylake setup.
My primary uses are:
* Games Developer (UE4)
* Games Player
* Core applications : GIMP, Blender, Sketchbook, MS Office, SQL Server
I do not have a budget but obviously I do not want to spend crazy money (I just do not know if I should temp build not holding off for the new x99 successor)
Cheers.
GPU: EVGA 980Ti
* Games Player
Cheers.
