Hi there,
I've had 2GB of ram in my PC for quite a while and i'm thinking about getting x2 2GB sticks, or x2 1GB sticks, but i dont know what to get, i checked overclockers and saw all this stuff like
with no idea if thats the same as mine and what it means etc.
those are my system specs, i just wanted to ask what type of ram should i get exactly, if anyone could provide a link to Overclockers.co.uk with the right one please?
i dont really like mixing and matching my ram either and would rather not spend more than £30 if thats possable,
any help is aprpeciated, sorry about being such a noob
whoops, should add, i did look for some my self, found these 2
http://www.overclockers.co.uk/showproduct.php?prodid=MY-142-CS
http://www.overclockers.co.uk/showproduct.php?prodid=MY-143-CS
(ignore those, just realised they're for notebooks
would those be ok for me to add the seem to be the same as what i have in there at the moment, and would you recommened 2gb or 4gb?
thank you
CAS 5, 1.8v SODIMM, Unbuffered, Non-ECC, Lifetime Warranty with Corsair.
Processor (CPU)
INTEL® Core 2 Duo E6600 (2 X 2.40GHz) 1066MHz FSB/4MB L2 Cache
Memory (RAM)
2048 MB CORSAIR DDR2 667MHz - LIFETIME WARRANTY! (2x1GB)
Motherboard
ASUS® P5W DH DELUXE: DDR2, x16 slot, 975X chipset, 2 PCI
Operating System
MICROSOFT WINDOWS® XP HOME (inc. Genuine CD & license) (£59)
Vista Upgrade
Upgrade voucher to Vista Basic/Premium with purchase of XP Home
USB Options
6 x USB 2.0 PORTS (4 REAR + 2 FRONT) AS STANDARD
Memory - 1st Hard Disk
160GB SERIAL ATA II HARD DRIVE WITH 8MB CACHE (7200rpm)
2nd Hard Disk
NONE
RAID (HDD 1 & 2)
NONE
1st CD/DVD Drive
18x +/- DVD WRITER (8x +/- Dual Lyr) (Lightscribe) (40x CD-RW) (£20)
2nd CD/DVD Drive
Graphics Card
768MB GEFORCE 8800GTX PCI Express + DVI + TV-OUT
2nd Graphics Card
NONE
Sound Card
INTEGRATED 8 CHANNEL (7.1 SURROUND) HIGH DEF. AUDIO
Modem
56KBPS INTERNAL V92 MODEM
Network Facilities
Onboard Wireless 54 Mbps LAN (802.11g) & 2 x Gigabit LAN Ports
Floppy Disk Drive
1.44MB - 3.5" FLOPPY DISK DRIVE
Memory Card Reader
NONE
Case
Stylish Silver/Black Trident case + 2 front USB
Power Supply & Case Cooling
600W Quiet Quad Rail PSU incl Case Fan & CPU Cooler (£69)
Firewire & Video Editing
ONBOARD 1394 FIREWIRE PORT
thank you
