I upgraded my CPU, motherboard and ram about 6 weeks ago and after a few days of doing the upgrade my PC started doing random reboots and had trouble doing restarts, by not posting.
So to cut the story short ,after weeks of testing the ram and motherboard for faults which their is none, updating and tweaking the bios and also getting advise off the Gigabyte tech support on bios settings for my setup. I temporary swapped my memory with a friend who was having problems with his crucial ballistix(2GB) after his 3rd RMA. I have been running it for the last 10 days with no problems at all and he has run my ram with no problems to.
So now I know the ram is just incompatible with my motherboard, which leaves me with the dilemma of do I just buy some more ram and do a simple swap or should I change my motherboard and upgrade to a P45 chipset?
This would also depend on how much I can get for my motherbaord, I thought £55.
This is the ram I would get and Gigabyte said would work well with my board
http://www.overclockers.co.uk/showp... EVO ONE DDR2 Dual Channel Kit (GE24GB800C4DC)
This the P45 baord I quite like
http://www.overclockers.co.uk/showp...P45 (Socket 775) PCI-Express DDR2 Motherboard
See sig below for my current spec
