Not sure where to post this, but get frame drops when using volume dial in windows10
7 Aug 2009
London
Hi guys,
Not sure where to post this, but I recently installed windows 10 on my new 3700x , vega 56 system.
I use a G19 keyboad with the volume dial, the thing is, when I'm playing games if i use the dial to turn the volume down, the windows 10 blue volume indicator pops up in the top left of the screen and actually causes a slight stutter and frame drops.
Any idea what could be causing this and how I could stop it?
Thanks
If you disable full-screen optimisations on the games executable the volume overlay probably won't show up. This will let you test whether it's the showing of the slider that's the problem.
Amazing, works perfectly mate. Now there are no frame drops when I change volume, must have been the visual slider causing the issue. Thanks!
