Not Sure which gtx 780 to get
21 Jun 2008
I've been looking at:
MSI Geforce GTX 780 Gaming Edition
http://www.overclockers.co.uk/showproduct.php?prodid=GX-209-MS&groupid=701&catid=1914&subcat=1341
and
Gigabyte GeForce GTX 780 Windforce
http://www.overclockers.co.uk/showproduct.php?prodid=GX-113-GI&groupid=701&catid=1914&subcat=1341
Main uses will be graphic design, After Effects, and some ZBrush, Maya etc (yes I know that the Quadro is better for this). Will be replacing my 3GB GTX 580 that's stopped working. I won't be oc'ing it at all.
If you have a better suggestion, let me know.
BTW, specs are:
i7 980x
24GB RAM
256GB Crucial SSD
Personally I would get the card with the stock heat sink and fan as although the MSI card will run a few degrees cooler it will dump a lot of hot air inside your case where as the stock will exhaust it out the back, Plus the stock one just looks awesome to boot :)
I can't speak for MSI but I have the WF and it's a great card. I doubt you could go wrong with either tbh! :)
