Not sure which one either!
2 May 2011
Woking
Pros for each one:
R290: Has free games, supports Mantle and other propriety AMD stuffs.
GTX970: Faster, produces less heat, uses less power, better over-clocking potential, cheaper, supports PhysX and other proprietary Nvidia stuffs.
NO fanboy here, because i've switched from AMD to Nvidia, the GTX 970 is definitely superior....in every way............even the Nvidia gaming experience software is way better than AMD Catalyst
if you've read all these posts then why are you starting a new thread, because it's pretty obvious that the 970 is superior...........or are you just trolling for an arguement !
Well from your comments, and benchmarks I've just had a look at, the 970 it is!
Hah I'm not trolling for an argument, Mal X. I'm just not a hardware sort of guy, so I need other people to tell me what to get :p
The GTX970 but I would try and get the Gigabyte one. AFAIK,Gigabyte RMA is UK based and MSI RMA is based in the Netherlands,so I would expect Gigabyte to have quicker turnaround times.
