Not Working
Try removing 1 stick at a time to see if there is 1 stick that won't less the PC POST rather than it just not being able to run 4 sticks
I beginning to think that the mobo does not support the ram
Whenever it crashes after changing the memory windows wont work and i have to reinstall, dont mater what you do it just resets the bios
Just Tried The Ram out my old PC and its working no problem at all, im using 4 x 1GB DDR2 667 (Cheapie stuff)
2 Branded Kingston
2 Branded Crucial
So does anyone else have this board and recommend a good compatible memory?
Right! Had The DDR667 In All Night And Its As Stable As A Hell, The Minute I Put So Much As 1 Stick Of The OCZ Back In Windows Will Blue Screen, The Bios Resets & Just Get Random Errors Before It Even Tries To Boot So I Think Its Def A Compatabilty Problem.
Will RMA It Back And Get Some Kingston To Try I Thinks!
The auld ASUS & OCZ gremlin back with a bang then lol
I'd have a gander at the QVL list on the ASUS website, then buy supported ram as to best avoid any more issues :)
