Note sure what laptop to go for...
26 Jul 2005
Hi all, currently looking for a laptop...
Budget: £1200 GBP
The laptop will be used for some light coding, usual web browsing (emails), multimedia and thesis write up. Occasional simulation work will be done which is CPU heavy. BUILD QUALITY is up there at the top, I need something reliable, sleek and solid. I occasionally be travelling with this laptop. Screen resolution and quality is also really important. I MUST be able to plug in 2 monitors at the same time.
Having a dedicated GPU would be a massive +
Currently I've narrowed it down to the XPS15 as it ticks all the boxes...HOWEVER the new models are out in Jan?
Could anyone suggest any other alternatives?
