Note taking app which offer taking handwritten notes and internal linking other than OneNote
5 Aug 2025
UK
Hey, I'm a Windows user and I'm looking for note taking that allow me to take handwritten notes and internal linking between different notes. And please don't not suggest OneNote I don't like it .(Cluttered UI)
I have been using Obsidian and can't praise it enough. It is free, although I pay for sync. And with the plugins there is so much you can do with it. It might take a bit of time to customize, but it is so worth it.
Linking works great through markdown and you get a big graph of how notes are interconnected.
Edit*
Just thought back to this video which is a great overview of how you can set it up and interconnect notes
Edit*
Yes I have heard Obsidian, but it looks more complicated to me, does it also allows handwriting?
It's as complicated as you want to make it. As it's markdown it is essentially one step up from writing in text files, it is much more light weight than onenote or notion.
The most used plugin is Excalidraw but there are a few handwriting plugins and OCR options, it might take a moment for you to find what works best for you.
I have heard concepts is good for visual notes as an alternative.
Thank you for your suggestion, I have researched about obsidian and thankfully it is allowing handwriting with a plugin excalidraw, it is looking perfect to me. Apart from this I’m also considering, notability app and it looks nice and offers handwriting features that I want. Now, I’m confused between the two, so I’m going to try both for some days, and will see which one is perfect for me.
