nothing happening with falmon on 1 pc
yep twice, and tried downlaoding again
Edit: although pressing the my stats tab it does go straight to the correct stat page for me, so it must be comunicating somewhere
Edit 2: Done it again on another PC, but i've done a 3rd PC this morning and it works fine
Check that the unit info text file its reading from is ok. Its in the folding directory. Delete the entries in fah mon and then start again, make sure your selecting the right folder.
If its near the beginning of the unit it can have problems identifying it sometimes.
they are OK, not as bad as the 56 point gromacs but not as good as the new gromacs with the double points.
it really is the luck of the draw with F@H. It makes it exciting anyway
HT
super, one more thing, any good stats sites that show each computer on my account so I can check they are all working. ( most of mine are on remote sites that I visit once a week. )
Ta
Babyface UK
If you find one, I'd like a link too.
I've never found one - but then, I've never looked particularly hard :o
Unfortunatly you wont find one. F@H doesnt save cpu information like the boinc projects do. It only saves the amount of cpus that are returning work units.
indeed - this is a feature that has been discussed since the dawn of foldy time I'm afraid, with the current stats system it's just not possible - doing so would require the stats to be reset which wouldn't go down too well :o
The only way of distinguishing between them is to put them on with seperate account names but then your stats will be all split :(
