Nothing is as aesthetically pleasing as my Stacker 820 :(
20 Oct 2007
I've been looking to replace my old CM Stacker 830 because the cable management is far from ideal (you can't get cables out the way behind the mobo) and while a lot of the newer cases I look at have brilliant cable management solutions, there's just nothing which looks as good (obviously subjective!) as the CM Stacker.
Specifically, I love the design of the side panels, the fact that the case has no right angles and the side panels have a nice shape to them at the back rather than just a straight line (and the panels overhang disguising all the exterior cables) and plugs means having it on show under my desk where you can see it side on really looks nice, here's a reference pic (google images, not mine)
Is there anything else around with a similar shape?
Would the side panels fit on another CM case (cosmos?) that had better cable management?
