Hi
Often, when starting up a pc of mine, running xp home, i click on icons to load programs and nothing will load. then after some time, anything upto 3 - 5 mins, all requested programs load at once. Any programs already loaded work fine. This often happens when i start windows. I've put a print screen of task manager. I am running winamp, IE, and FF, but other than that, its just as it would be when starting up - any ideas?
(btw when nothing is loading, the computer isn't busy)
This has happened even after just a few days of a clean install, with very little programs installed. Its been happening for ages, decided this half term i need to sort everything out like this
thanks
thanks
