Nova-t-500 PCI Problems
1 Dec 2004
S.Wales
Hi, iv just purchased this card and have it working with Media portal, I have a few problems with it at the moment though:
1) When PC comes out of hibernation, no signal is being recieved by the card thus if a scheduled recording has been programmed, it will not work.
2) I cant seem to get the 2nd tuner to work, I can record one channel but if I go to view another one, I simply get "Tuners are busy". In the card config and media portal config I can see both tuners listed.
Card has the latest drivers installed and im using XP SP3.
I just built a media pc using the same board and a leadteak tuner card and have exact same problem. solution? s1 standby.
try using this app, to see if your second tuner is working ok (some are faulty)
http://www.hauppauge.co.uk/board/showthread.php?t=12082
Standby has always been a problem, its more likely to do with your motherboard, rather than the card.
Just been on google for abit, it does seem like its a common problem with the TV card RE waking up from hibernation, does anyone know if there is a fix for this?
Iv run the app, both tuners are recieving signals as they should be, being again in media portal, record one channel and when i goto view another i get the message "tuners are busy"
