NovaBench Benchmark Scores
23 Oct 2009
Derbyshire
Free, lightweight benchmark that tests everything on your PC.
If you're going to run it, simply install and run at stock settings.
DOWNLOAD
Test the main components of your computer quickly with NovaBench.
Testing generally takes only 1-2 minutes, and produces detailed information and an overall system score.
· Floating Point Test - Tests CPU's floating point arithmetic speed
· Integer Test - Tests CPU's integer arithmetic speed
· MD5 Hashing Speed - General CPU test
· 3D Graphics Test - Tests GPU with a heavily shader dependent 3D scene
· RAM Speed - Tests RAM read and write speed
· Disk Write Speed - Test write speed of primary or selected storage device
Compare
Compare your computer's score and system component results to others.
Make informed upgrade decisions, and easily detect performance bottlenecks.
All results submitted to NovaBench.com are verified for authenticity.
Share
Build a profile of your NovaBench results, and link it easily on social networks.
You can also create an image for your forum signature, blog, or website.
My score, rig in sig.
[/URL]
im thinking maybe i should stuck windows on my ssd not had it set up as caching drive guess ill wait for something to go wrong give me excuse to reinstall windows the right way around
