- 11 Jul 2010
Hi all.
So I recently decided to make the jump and join the world of dual monitors, simply because I see how much easier things are without having to alt tab etc all the time.
But I am at my absolute whits end with it already.
So I have an nVidia 780, and the spare ports on the back are a DVI-D (I believe, I'm not great with names, hence being a novice haha) an HDMI, and then another HDMI looking port but slightly bigger.
My second monitor is a AOC E2070S, which is VGA only.
Apparently, correct me if I am wrong, but DVI-D to VGA doesn't seem to be a thing. I did buy an adapter that did actually fit in said slot (Just under the DVI one) - but didn't work in the slightest.
So then I bought an HDMI to VGA lead, this is where I started getting a little frustrated! I hooked it up, nothing, so I restarted - when I restarted, the login screen wouldn't show when I booted up :/ It's just a blank green screen (My background color is green), but if I typed my password, and hit enter, I could get onto the desktop - bit then I can't see my mouse or any right clicks (So unless I manage to guess where the mouse is, and where the drop down box is, you get the idea, I can't do anything in terms of trying to detect the second monitor)
And then to get my screen fully back, I have to unplug the HDMI to VGA and restart, but then when I've booted up and plugged back in - I can't detect it.
I tried downloading and installing some Windows 8.1 drivers for my GPU but that didn't change anything.
Does HDMI to VGA even work?
I am on Windows 8.1 64 Bit, and my graphics card is a GeForce 780 GTX
Please help! Thanks!
