- 28 Sep 2017
Be Quiet have released the new Silent Base 601, now available at Overclockers UK from £114.95!
It's a quality mid-size case with an abundance of features including:
- Noise dampening vents that are angled to reduce sound output
- Extra thick noise dampening insulation in the front, top and sides.
- 2 x Pre-installed Pure Wing 140mm fans (1000 RPM)
- Fan controller with support for an additional 120/140mm fan (5V/8V/12V settings)
- PSU shroud and smart HDD slot covers provide a neat interior
- Support for up to 2 x 360mm radiators front*/top and an additional 140mm at the back. (*If the PSU shroud is split to the smaller option).
- Removable top mounted fan/radiator bracket for easy installation.
- Dual HDD Cage beneath the PSU Shroud, with an additional single HDD cage in the main compartment. Each with anti-vibration fittings.
- Storage options for up to 7 x 3.5" HDDs (3 cages included) or up to 14 x SSDs (6 included).
- Front Panel access to both the front and bottom dust filters for easy maintenance.
- Tempered glass side panel or fully enclosed variants.
- Case size incl. stands (L x W x H), (mm): 532 x 240 x 514
- Front I/O HD Audio, 1 x USB 2.0 and 2 x USB 3.0.
If you'd like a more in-depth look however, check out the review by Leo over at KitGuru!
be quiet! Silent Base 601 Midi-Tower Case - Orange Window @ £124.99 inc VAT
be quiet! Silent Base 601 Window Orange delivers the perfect combination of maximum silence and an excellent usability for remarkably quiet configurations.
Only £124.99 inc VAT.
ORDER NOW
be quiet! Silent Base 601 Midi-Tower Case - Orange @ £114.95 inc VAT
be quiet! Silent Base 601 Orange delivers the perfect combination of maximum silence and an excellent usability for remarkably quiet configurations
Only £114.95 inc VAT.
ORDER NOW
be quiet! Silent Base 601 Midi-Tower Case - Black Window @ £124.99 inc VAT
be quiet! Silent Base 601 Window Black delivers the perfect combination of maximum silence and an excellent usability for remarkably quiet configurations.
ORDER NOW
be quiet! Silent Base 601 Midi-Tower Case - Black @ £114.95 inc VAT
be quiet! Silent Base 601 Black delivers the perfect combination of maximum silence and an excellent usability for remarkably quiet configurations
ORDER NOW
be quiet! Silent Base 601 Midi-Tower Case - Silver Window @ £124.99 inc VAT
be quiet! Silent Base 601 Window Silver delivers the perfect combination of maximum silence and an excellent usability for remarkably quiet configurations
ORDER NOW
be quiet! Silent Base 601 Midi-Tower Case - Silver @ £114.95 inc VAT
be quiet! Silent Base 601 Silver delivers the perfect combination of maximum silence and an excellent usability for remarkably quiet configurations
ORDER NOW
