***Now In Stock*** Western Digital Solid State Hybrid Drives
7 Feb 2011
Stoke on Toast
Western Digital Caviar Blue 4TB 3.5" SATA 6Gb/s SSHD - (WD40E31X) @ £132.95 inc VAT
WD Blue Solid State Hybrid Drives (SSHD) combine a generous amount of NAND flash SSD technology and massive HDD storage capacity into a single drive. WD engineers team up the best of SSD and HDD to produce a hybrid that can increase overall system performance – resulting in quicker system boots, faster application loads, and improved responsiveness when compared to traditional hard drives.
Specifications:-
- Capacity: 4000 GB
- Edition: Blue SSHD
- Form Factor: 3.5"
- Height: 25.4 mm
- Cache: 64MB
- Access Time: N/A
- Interface: SATA III - 6Gb/s
- Dimension: 69.85 x 9.5 x 100.2 (WxHxD mm)
Only £132.95 inc VAT.
ORDER NOW
Western Digital Caviar Blue 1TB 2.5" SATA 6Gb/s SSHD - (WD10J31X) @ £68.99 inc VAT
Specifications:-
- Capacity: 1000 GB
- Form Factor: 2.5"
- Height: 9.5 mm
- Cache: 64MB
- Access Time: N/A
Only £68.99 inc VAT.
ORDER NOW
View the Whole Range of SSHD's Here
Interested in one of these, but holding out for bigger nand versions.
Is it really that hard to for manufacturers to put the RPM speeds of their drives into their descriptions? I've trying to find out the RPM for the 2.5 driver and even WD's own website and PDF spec sheet doesn't have it. WTF.
WD Blue WD10J31X 1TB 5400 RPM 64MB Cache SATA 6.0Gb/s 2.5" Laptop SSHD Bare Drive
Haha, you gotta feel bad for Seagate, they spent years getting this niche off the ground and then WD just walk in "yup, we're aving some of this action!" XD
Take away speed by making it 5400rpm, and then add back with Nand - daft.
Not really - 7200rpm laptop drives compromise power and noise, for a small improvement in transfer rate and access time. Whilst the Nand will do very little for the transfer rate loss, assuming the caching algorithm is decent enough, it more than offsets any loss in access time.
A bit more NAND would likely work wonders in these though (although I fine line vs the cost I would guess). A 2TB/64GB NAND version would be great for laptops and Playstations though :)
I was told that SSHD drives were naff?
You were told wrong then :)
Yes they are not as quick as an SSD, but they bring SSD like qualities (e.g. improved boot speed, faster directory listings) to drive capacities that are otherwise expensive.
