now should i bid?!
Do it!!! :p
Its only 250. It looks to be fun to drive and it would definatly be a head turner :D
Firestar_3x said:
Load Space: 3.0m x 1.8m x 1.8m
Load Space: 4.0m x 1.8m x 1.8m for the LWB.....
Total length × full × total height: 2790×1295×1650mm
for the midget, is that size for the oldish tranny?
Vehicle weight: 590 kg
Engine type: Serial 3 cylinders SOHC
Total cubic displacement: 660 cc
The highest output: 31 PS/ 4900 rpm
Largest torque: 5.1 Kg-m/ 3200 rpm
Drive system: FR
Wheel base: 1840 mm
Tread (F/R): 1135/1100 mm
Brake (F/R): Drum/drum
Suspension: F マクファーソンストラット
R rigid axle leaf spring
sounds like a drift machine :D
Drive system: FR
Wheel base: 1840 mm
New tranny taken from a hire website.
You need to cut out the pickup back and fit a motorbike engine ;)
