Now that's a USB hub!
1 Apr 2014
Aberdeen
Do you need 49 USB 2 ports? Look ye here!
I know I'm one for USB devices - I have a 13-port hub - but this seems like complete overkill. Of course, there's no kill like overkill! :)
I can't think of any reason why you would??? I've you have that many devices for say storage then you should be looking a switch or NAS anyway.
Technically, each controller allows up to a maximum of 127 devices each sharing the half duplex 480M/bps bandwidth of USB 2 although this has increased top 5 and 10 M/bps for USB 3 and USB 3.1 respectively.
Although the speed is very much welcome i've never had more than half a dozen devices connected at one time. Mouse/Keyboard/Printer direct to motherboard then hot swapable mobile phone/External backup drive/Xbox controller into the FP as and when needed.. that's it.
The Cambrionix ones are very good if you need to connect and charge a whole bunch of USB enabled things.
10 port ones are great for automated testing of such devices.
hmm, hotas warthog = 2
Trackir5 = 1
Cougar MFD's = 2
lilliput screens for above MFD's = 2
mouse+keyboard = 2
rudder pedals = 1
trim controls = 1
total = 11, im getting there :P
