NR200P Max vs Max v2
18 Oct 2002
Leicestershire
Anyone found a proper side by side comparison between the original and the v2 Max?
Half tempted to buy one to build my 'server' in, and then use my original case to put the offsprings machine into to keep temps under control...
Funnily enough, I just built a gaming box in the V2, as far as I know, the front panel now has USB-C, the PSU has the 12v HiPower connector for Nvidia and the side panel has a different pattern (which I don't like as much).
I’m pretty sure the V2 PSU has a different fan curve. The original 850w unit had a poor fan curve which they resolved with a revision and the Max was pretty good in this regards. But now the PSU is a 3.0 it’s had some changes and I am certain I read the unit is a bit noisier now.
Hmmmm, tempted to rebuild the offsprings H1v2 into an NR200 but shes moved to a laptop so the machines not really in use, I do like to faff though...
