ntfs and ZFS question
29 May 2005
Right, I am looking to migrate my NAS data from NTFS (windows based server) to ubuntu ZFS system (raidz1).
I assume it should be a straight forward rsync process with both the ZFS and NTFS drives plugged in?
thanks
It should be, however prior to running the migration you may want to set the following pool properties:
  • Set 'xattr=sa' to store extended attributes in inodes rather than hidden files; this should improve performance however I'm unsure whether there may be a negative impact in terms of compatibility for some clients (it doesn't seem that there will be).
  • Disable 'atime' or set 'relatime' if the former causes issues.
