as i mentioned here last night, my connection keeps dropping every so often for about 15 seconds, not enough to kill my net but enough to make it impossible for me to game online.
i just wonderd if anyone had any theories on why its doing this and what the logs mean...
070108192138 5-Warning D103.0 DHCP RENEW WARNING - Field invalid in response
070108192138 4-Error D530.8 DHCP - Invalid Log Server IP Address.
070107012137 5-Warning D103.0 DHCP RENEW WARNING - Field invalid in response
070107012137 4-Error D530.8 DHCP - Invalid Log Server IP Address.
070103132137 5-Warning D103.0 DHCP RENEW WARNING - Field invalid in response
070103132137 4-Error D530.8 DHCP - Invalid Log Server IP Address.
070102054540 7-Information H501.6 HFC: TRC SYNC Recovery OK
070102054538 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
070102054538 7-Information H501.12 HFC: FEC LOCK recovery OK
070102054538 3-Critical T5.0 SYNC Timing Synchronization failure - Loss of Sync
070102054534 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
070102054534 7-Information H501.12 HFC: FEC LOCK recovery OK
070102054534 3-Critical T5.0 SYNC Timing Synchronization failure - Loss of Sync
070102051304 7-Information H501.6 HFC: TRC SYNC Recovery OK
070102051302 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
070102051302 7-Information H501.12 HFC: FEC LOCK recovery OK
070102051302 3-Critical T5.0 SYNC Timing Synchronization failure - Loss of Sync
070101115705 7-Information H501.6 HFC: TRC SYNC Recovery OK
070101115703 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
070101115703 7-Information H501.12 HFC: FEC LOCK recovery OK
070101115703 3-Critical T5.0 SYNC Timing Synchronization failure - Loss of Sync
070101115700 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
070101115700 7-Information H501.12 HFC: FEC LOCK recovery OK
070101115700 3-Critical T5.0 SYNC Timing Synchronization failure - Loss of Sync
070101115244 7-Information D507.0 Retrieved Time....... SUCCESS
************ 8-Debug M571.6 CM Cert Upgrade Enabled. Initiate via SNMP
************ 8-Debug M571.9 Missing CM Cert Upgrade TLVs.
************ 8-Debug M570.1 Motorola CM certificate required
************ 8-Debug X501.4 Provisioned Unit Update skipped. Image is current.
************ 8-Debug I503.0 Cable Modem is OPERATIONAL
