Ntl help
31 Dec 2004
I have ntl broadband running from my settop box can you split it with a router to a mac and a pc without any problems? . Any advice is good thanks
Yes you can but if NTL STB's are anything like TW STB's (and they are) then you may want to cinsider getting a modem instead of the STB as the modem port is limited to approx 1.5-2mbit. Sormicroft is your best bet to ask on the NTL side of things.
Either way a router will do exactly what you want and more.
