ntl to projector problems
9 Mar 2004
hi just purchased a projector,got it connected to the ntl box scart to back of pj svideo cable,picture is in black and white anybody know of a solution as to why this is,have i bought the wrong cable.
NTL box doesn't support s-video, if it did there would be a menu option for it.
could you recomend what i need then,i think the ntl is set on rgb but the projector only accepts svid component and composite,is there such a thing as a rgb scart to svid lead.
There's always ways of converting signals but as that shows they aren't usually cheap.
Goatboy said:
you can't get scart to component though which is what he would need
So whats the difference between a Scart to componant and a componant to Scart ? If you do a Google for Scart to componant it comes up with enough hits though like systemsdead said it would cost a lot of money for a 10M one.
They only convert the signal one way.
