NTLDR is missing ! HeLp
30 May 2006
leicester
on my second rig on the same spec as below when it loads up all the device before it gets in to windows it reads ntldr is missising it then just tells you to restart which is very frustating you do this and it carry on bringing up the same message my bios is all correct the only thing i can think of what might have upset the rig is leaveing a pc gamer disk in the disk tray and turning the it off and then back on the followering day pc back with the disk still in the tray :confused: whereever it tried to boot from the disk i dont know but any of your suggestion wouldd be helpful
thanks
smiley
Try putting the Win XP CD in the drive, changing the boot order to boot from CD first and when the XP install screen appears choose the "repair" option. This will take you into the recovery console and you can type in either "fixboot" or "fixmbr" (without the quotes). That should get you going.
Brian
i do all what you say and when i get to system repair tool i can only put in one letter :confused: so i try and put fixboot in and all it write is f every time i try i have restated and keep trying but still the problem persits the only other thing i can think of is that my windows xp professional disk is a copy of a friends and maybe it corrupted but it has always worked before :confused: any help would be appriciated
smiley
It shouldn't matter which XP cd you use.
Do you get the prompt to select a keyboard (I think it says something to the effect, press a key to select a non-default keyboard)
Also do you get to the screen to enter the admin password (this won't appear if there is no local admin password)
Personally I would make sure all disk are plugged in, detected by bios and you are booting of the correct disk. If you say try and boot of a second hard drive with no windows install it will give you this error.
Check that there is no USB hard disk plugged in that it is trying to boot from.
Especially careful if its a SATA disk you are wanting to boot from in preference to a IDE disk.
Ric.
i do not get the prompt to select the keyboard and all it let me wright is a single letter in the window repair tool all my disk appear to be right with harddisk first to boot my harddisk is sata so therefor it is sata master no1 while my 2 dvd drive are primary master and primary slave also i have only this one harddisk which has got window on and i have no usb harddrive attached
IIRC you have to select which partition you want to repair first, hence you can only enter 1 letter, corresponding to the partition letter. Presuming you only have one partition this will be C, so at the prompt type C and press enter. Then it may ask for a password, leave it blank and press enter and you should be at another prompt. Now type fixboot and press enter, then after doing that type fixmbr and press enter. Reboot and hopefully it will have worked.
it says it reqiure an adminastaters password i have no idea what i could be because i have put no password :confused: on the computor any help plz
I am amazed to find this topic here since I had exactly the same problem last night at exactly the same time!! Very spooky. I still haven't been able to fix it.
Basically I was trying to partition the hard drive and the partition software corrupted some of the data so that I always ended up with a BSOD when I was trying to boot Windows. The BSOD always came before the XP boot screen appeared.
So I told the BIOS to boot from the XP disk, opened the repair console and ran FIXBOOT which told me that the boot file was corrupt, so it wrote a new one. After restarting, I still got a BSOD before XP could load. So I ran the repair console again, ran a CHKDSK [which told me that the hard drive had one or more unrecoverable errors] and ran FIXMBR. After this I got the same problem as the thread starter here - after the VMI pool data was verified - "NTLDR is missing, please restart".
I have no idea what to do now, I'm thinking I may have to format the hard drive and reinstall XP. I tried to run the BOOTCFG in the repair console but I was told there were too many errors on the hard drive to run it!!
Anyone got any ideas - this topic is a last resort otherwise I'll have to reinstall XP tonight which I'd rather not do. Hopefully we can work through this together! :p
OK I've found a couple of help pages about exactly this problem here -
http://www.computerhope.com/issues/ch000465.htm
and
http://support.microsoft.com/?kbid=314057
Look further down this page too... there may be something there.
http://www.techwarelabs.com/communi...start=15&sid=f86d12254d5a30ebc1408d9fa6d3ebb6
This MAY work - try it and let me know - I'll give it a go tonight.
I had the same problem, here the FIX
Boot the W xp CD, en E [or R] for repairconsole
To replace damaged ntldr and ntdetect.com you can copy fresh files from the XP CD using the COPY command. At the Command Prompt type the following
COPY D:\i386\NTLDR C
COPY D:\i386\NTDETECT.COM C
(d: = cdrom, or whatever you use)
type FIXBOOT ...
Reboot and ENJOY
Further topics here - esp at the bottom of the page.
http://www.softwaretipsandtricks.com/forum/windows-xp/3102-ntldr-missing.html
ignore my last post guys
i got past the adminastarter password and ran fixboot it says it created a new partion but when i turn the pc back on still the same error i done the same thing again but still no joy. do you think i should copy the folders of another healthy computer and make the computoer boot with these files on a memory stick or have you lot got any better ideas.
Why don't you just look at my post above yours? That's what I'm going to try tonight. FIXBOOT didn't work for me either. Just copy the files from your XP CD.
Hey dude, i got the exact same message when i had a second hdd in my pc which failed! I also got that message when i put a hdd in a new pc without formating :rolleyes:
Some possabilities there :)
smiley said:
keep me informed lysander wheter it worked
Well, I had a go and got absolutely nowhere. I couldn't even get into the admin console - if you can, you stand a better chance but I had to reformat the drive and install XP again.
XP now runs fine but I can't get onto the internet from that machine. It says all the IP information is 'unavailable'. :confused:
i ll do mine pc on saturday hope i have a bit more look than you lafyer lol
mine should do the job i hope lol
