NTP Question
23 Oct 2002
_
Why does NTP use UDP instead of TCP? :confused:
Is it because UDP packets can be smaller the TCP to speed up delivery?
NTP is usually multicast on 224.0.1.1 which means that if your running NTP in a network, hosts only need to receive one copy of the information it sends once, it does not need any bidirectional communication or acknowledgments. UDP is fine.
