Ntune & 97.92 not working
27 Dec 2003
UK PLC
Anybody got this combination to work, the monitoring is ok but it crashes if i use the auto over clocking (find max OC) and the manual OC feature wont turn on.
Any ideas.
Cheers
Any ideas.
Cheers
Same here. Use RivaTuner instead.....
pegasus1 said:
Cheers mate, im gonna wait till attached to my waterloop before i try any major OCing.
RivaTuner doesn't work with Vista by the way in case you're using.
