NUC Wifi in Akasa Passive Case
20 Oct 2002
Derby
I recently purchased an Akasa Newton P for my Intel NUC (NUC5CPYH) but after I finally get in built yesterday I realise that there is nothing associated to sorting the wifi. It looks like there is a hole on the back to fit a place for the Antenna to fit but not included or with no cables/antenna.
So does anyone know what exactly its called? I believe its called a WIFI Pigtail but the only ones I have seen have only 1 cable and my wifi module has 2x very fine connectors for the wifi antenna.
Any help would be appreciated :)
HUACAM HCM16 2 x 2.4GHz 6dBi Indoor Omni-directional Antenna 802.11n/b/g RP-SMA Female Connector + 2 x 12cm U.FL Mini PCI to RP-SMA Pigtail Antenna WiFi Cable
Much appreciated matey.. :)
Is there a way to use just one antenna as there is only 1 hole in the case?
Also will those connectors on the wifi module fit? The module is a m.2 one with the smaller connectors than the m-sata wifi modules?
