Hi There
I've just invested in a NUC for my Windows 7 XBMC HTPC Setup
I would really like to use a IR remote if poss as the NUC i've gone for has the built in IR sensor.
I've been doing a little reading around and found out that the xbox 360 (black) remote control could be used with the NUC, however I cannot find a clear answer if it can or cannot.
Does anyone know if you can use this?
Also what will it control in Windows 7 as I plan to use Ultrastar Deluxe (Singstar Karaoke PC Clone) and just wondered if it would work with that also (within windows etc)
Cheers
Pete
Cheers
Pete
