NUC11 threaded screw - help!
23 Mar 2004
Yorkshire
Hi folks,
My NUC11 stopped switching on recently, I thought it may be the mains adaptor but a USB connected device is being charged so I presume it might be the switch.
So I tried to disassemble the NUC but I have a cross threaded screw I can't remove to even get the board out.
Here's a general shot.
And here is the corner view, right by the RAM slots.
It's weird as you would think the screw should be in the hole next to it rather than this weird position, especially as the other screws were in the other corners.
My heavy handedness has made it worse.
Any ideas how to get this out?
I tried supergluing a Philips head to it but no joy, not strong enough.
Any help would be gratefully received.
Looking at a video i found, the four corner holes are for joining the case top and bottom together.
There is only two screws holding the motherboard.
You could try epoxy glue to glue the screw head to a old screwdriver/allen key.
Don't get any on the motherboard or case and it takes a long time to fully cure.
Pretty hard to cut a slot given the size and location. At least with my lack of skills and tools.
Will give the drill a go and see if I can get it off/out.
Id suggest you use a left handed drill bit which drills in reverse mode on drill machine that way no risk of pushing it in further.
I tried something similar with superglue but didn't work as not strong enough, I presume the epoxy stuff is a lot stronger?
Something like JB Weld is a lot stronger than superglue.
I'm not saying it will work for definite, but it does have a better chance.
You could drill the top off the screw and see if you can lift the motherboard out and then use pliers to remove the threaded part.
Be carefull of the bits of metal though and make sure to clean them off the motherboard.
I'm a JB Weld fan, but I think the chance of it not immediately cracking when force is applied on the small connection area it has, is extremely slim.
Can you not disassemble the whole nuc and pivot to an akasa fan less case or similar? Would allow you to cut back the housing of the nuc OEM case then
It seems like you can only get full access from the base.
This is the top
I removed the 4 corner screws which I think hold the metal fan assembly in place but you can't get this out from the top. At least I can't see a way to do so.
This is the top
Depends on the series, but my gung ho approach next might be to unscrew everything else I could, and I would then consider cutting away the case even. An excuse to upgrade the case perhaps.
Although seriously you might end up with the same limitation of the rounded screw.
Not sure if you can araldite on a hex or spline fitment or similar?
So I went with the drilling the screw approach and this worked well.
Was still a ball ache as the motherboard wouldn't come out on its own as I've seen on other models but the whole metal surround came out and then I was able to get the board out.
Ta da.
The problem I have to deal with now is the sucker not booting.
If I plug the power supply in I can hear a feint clicking noise, pressing the power button doesn't do anything, fan doesn't attempt to spin or anything.
Any ideas folks?
I could order a replacement psu to entirely discount that being the problem. But I am getting power from the usb sockets so that kinda makes me think it's the board.
It will be out of warranty and Intel have passed all that to Asus now so I feel that's gonna be painful and expensive.
