Hi all. I've been asked to look into building a number crunching machine for work. This machine would just be used for computations. A decent amount of RAM would be good as quite often we end up with large meshes to analyse. I've been slacking when it comes to reading up on hardware as of late, so I'd appreciate any suggestions.
The last machine we got for this purpose was from Dell. It has two Intel Xeon E5520s for processors, memory is 18 GB (3x4GB + 3x2GB) 1066MHz DDR3 ECC-RDIMM and the OS is Windows 7 Professional 64 bit. This cost about £2.5k at the time and I'd be looking to spend a similar amount and get a similar or better performance. I'm aware that the budget isn't huge in performance computing terms, but that's all I have to work with.
Is a two CPU system the way to go? Or should I look at getting a single CPU of a higher spec?
I'm open to any ideas.
Other than that it's fine. You might want to go for 2x drives in RAID1 as a minimum for backup.
