I have 8x6 on both of my bikes. Looks much better than standard without attracting any unwanted police attention.
I've used THESE for the last 4-5yrs. Not as cheap as eBay, but you can order suitable nuts/bolts n sticky pads etc. too.
I normally run with 7x5, never had an issue after stopping and talking to the Police many times. Got a 8x6 on my Speedy, but that's mainly due to the size of the mounting plate it fixes to.
Edit: Never had to change them for MOTs either, but I guess that depends on how well you get on with your tester![]()
Cheers for the link, that looks great!![]()
I assume the plates are still reflective etc so legal apart from the size?
Technically classed as "show plates", but basically the same as normal plates bar the size and dealer name etc.
You can actually choose to have your own subtitle on the bottom of the plate if you want tooAnd various finishing options, like 3D lettering/honeycomb background etc.
What size was it Tefal?
