Numpty CPU fan direction question
14 May 2007
London
Should the fan suck or blow (oo'er missus) the air? Seriously, does the fan on the CPU blow towards the case fan? In which case which way should the fins be on the fan?
Sure this has been answered so apologies in advance.
I would have it blowing through the heatsink towards the rear case fan that should be blowing air out of the case (depending what cpu cooler you have).
I think it should blow, If you just fit it to the socket the correct way then you shouldn't need to think about this should you? Can You Change the direction of the fans?
