NUS case
Am I being completely thick and misunderstanding the question? If you changed your NUC into the Akasa housing, what did you do with the original NUC housing?
If it's purely the footprint you're after, try looking at the Streacom and Impactics units. But I have to say, even the fanless NUC housings are really tiny, so I can't see the footprint being an issue.
But that's just my opinion. I don't think you can actually get empty Intel stock housings.
Well done!
Seriously, I've had a quick look around and either my Google Fu fails me, or you just can't get the original NUC housing individually (I can't even find any broken NUCs to rip bits from).
