Nuts & Bolts
17 Nov 2011
I've 2x140mm fan filter for the top of my case which doesn't have fans installed but screws don't fit so I'm wondering what size bolts/nuts will I need?
M3 nuts and bolts should fit. Depending on the head size/nut size, you may also need some flat washers. Rubber washers would be even better because they should reduce any vibration.
