NV_RGBFullRangeToggle?.
Try it but it will probably look the same. The new drivers let me toggle and it looks and works fine now. Limited makes things overly dark with lots of black crush and full gives me proper blacks it is really easy to see if it is correctly set in games. Maybe next time you format make sure your screen is in the right mode first because there are checks done for the default mode before driver install.
Simply view a checker pattern and black should start at 0 where as on limited it starts at 16 and everything below this gets crushed and rendered as black too when in reality 15 would be a grey and not black. Understand? :)
