Nvida GeForce 8800 GPU Diode Temp
31 May 2005
Hi to all, i tried searching for a similar thread but didnt manage to find one, I currently have an Nvidia BFG GeForce8800 OC. I use everest to check out my temps, after playing a game the GPU diode would reach around 70c, is this a normal temp ?? or is it overheating ?
Iam also posting a screenshot of the temps everest gives me when the pc is idle.
Thanks for any help.
hi RJC sorry for the sig, its arranged now iam using a zalman cpu cooler thanks for your replies at least i dont need to worry then for those temps.
Thanks once again.
Thanks once again.
can only have 4 lines off text.. FAQ
Holy 8 lines Batman! :p
To keep it within the *golden* 4 line rule it needs to be looking something like this:
Asus M2NE-SLI | AMD Athlon X2 DUAL CORE 3800+
3GB DDR2 RAM | Samsung 400GB HDD SATA II
BFG OC 8800GTS 320MB | Zalman CNPS9700LED
Xilence 550W PSU | Windows Vista Ultimate (32-bit)
My Leadtek 8800GTS also idles in the 60's and load is >80C due to having CPU watercooling and almost zero case airflow, I'm not that bothered about it as the card is super stable, even overclocked to 650/2000Mhz
Echo the above, that temps fine for underload, mine idles about 53-54, underload ive only seen it go as high as about 76, but i think even early 80's would be fine for underload.
