Nvidea driver issues with any driver after 365.19
27 Jan 2006
Newcastle
Hi ,
I'm running windows 10 64 bit, Titan x in sli. I also have a second monitor monitoring teamspeak etc when in games.
My problem is I can't get a single driver to work after 365.19.
things I've tried
Used a driver utility to remove drivers completely and did a clean custom install
Failed.
some drivers will install then crash as I re-enable sli.
as soon as I re-install 365.19 everything is fine.
problem is I wanted to run the new battlefront beta which required upto date drivers.
Any idea's guys?
thanks in advance
Hi ,
things I've tried
Failed.
Any idea's guys?
thanks in advance
Are both cards ok? Would test them one by one to see if there are any issues, and maybe even try a second sli bridge. If everything is fine and dandy, try reinstalling Windows (could be some corrupt **** somehwere causing issues with newer drivers).
