Nvidia 197.28 forceware ( quadro inf modified )
Caporegime
8 Sep 2006
On Ocuk
win7-Vista 32-bit:
http://www.nvidia.com/object/Quadro_win7_winvista_32bit_197.28_whql.html
win7-Vista 64-bit:
http://www.nvidia.com/object/Quadro_win7_winvista_64bit_197.28_whql.html
XP 32-bit:
http://www.nvidia.com/object/Quadro_winxp_x32_197.28_whql.html
XP 64-bit:
http://www.nvidia.com/object/Quadro_winxp_x64_197.28_whql.html
New in Release 197.28:
* Adds support for CUDA 3.0 for improved performance in GPU Computing applications. See CUDA for more details.
* Adds support for the Open Computing Language (OpenCL) 1.0 in Quadro FX Series x700 and newer as well as the FX4600 and FX5600.
* Workstation application compatibility fixes and performance improvement. Please read the release notes for more information on product support, feature limitations, driver fixes and known compatibility issues.
* If you would like to be notified of upcoming drivers for Windows, please subscribe to the newsletter.
Existing Support:
* Supports NVIDIA SLI technology (two-way SLI) for DirectX 9, DirectX 10, and OpenGL on SLI-certified Intel X58-based motherboard based system from select OEMs.
* Includes full support for OpenGL 3.2.
* Added support for DDC-Ci/MCCS over the DisplayPort AUX channel.
* Added 10-bits per color (10bpc) DisplayPort support for full-screen applications on supported products.
WIN 7 64bit Inf
http://www.mediafire.com/?jnyitxur0zz
WIN 7 32bit Inf
http://www.mediafire.com/?nmnt3i0y2mi
