Hi Community,
I have a thread posted in the Motherboard section with the background on this issue. But I wanted to throw up a topic here as this question concerns my graphics card alone.
Following the sending in of my tower for repair, the repairman has diagnosed an issue with the display ports on the MOBO. Said issue appears to be affecting the connection with my GPU and somehow the rest of my computer.
I'll level with you guys. I really cannot afford a new GPU (mine is still within warranty with NVIDIA) and someone has pointed out that the current climate is poor for buying/replacing GPUS. I have asked him to make sure that the GPU is not faulty and he has said that it is not, but that he cannot guarantee that any part will not fail within a 3 month period.
My question is. If my GPU were failing or not long about to die, would there be some telltale signs that I should look out for that indicate I need a change? Are GPUS like the 2080 generally sturdy or unpredictable?
Thanks!
Thanks!
