Nvidia 267.05 WHQL Quadro
Caporegime
8 Sep 2006
On Ocuk
http://us.download.nvidia.com/Window...glish-whql.exe
RELEASE NOTES
CUDA 3.2 for improved performance in GPU Computing applications. See CUDA for more details.
NVIDIA Mosaic
This release introduces the new NVIDIA Mosaic Technology, supported only under Windows 7.
NVIDIA Control Panel Updates
General Interface
The System Information page now shows the DirectX version supported by each GPU
Added Multi-GPU Visual Indicator
3D Vision / Stereoscopic 3D
Added 3D Vision Pro controls for use when a 3D Vision Pro hub is connected.
Added stereoscopic 3D windowed mode support for select 3D programs, including Google Earth
3D Vision
Added support for 3DVisionLive.com Beta2
Supports 3D photo sharing and viewing
Workstation application compatibility fixes. Please read the release notes for more information on product support, feature limitations, driver fixes and known compatibility issues.
If you would like to be notified of upcoming drivers for Windows, please subscribe to the newsletter.
Existing Support:
Support for the Open Computing Language (OpenCL) 1.0 in Quadro FX Series x700 and newer as well as the FX4600 and FX5600.
Support for OpenGL 4.1
Support for Directx11
The new 267.x series :D
Waiting for INF mod!, p.s Generally i stick with Quadro's over Desktop drivers as they are of high quality there was a post about this awhile back if i find it :)
