Hey,
Really interested in a 2D Surround setup for gaming.
I currently have from my initial purchase form OCUK back in 2008...
2 x Samsung SM2693HM 25.5" Widescreen LCD Monitors
Now for the life of me I cant find this monitor anywhere now. Its a shame its a great monitor. So I'm looking at the...
Hanns.G HZ281HPB 27.5" Widescreen LCD Monitor - Black [HZ281HPB]
Both are 1920*1200, obviously the Hanns.G is going to be taller but as I understand it this should not be a problem?
The Response Time is said to be better on the Hanns.G, as well as better contrast ect. If I remember correct. It has a max refresh rate of 75 I think, but this can be changed back down to 60 correct?
Apart from any possible technical issues? I should be able to just level the monitors. Since the taller Hanns.G is in the middle and pretty long, the 2 side monitors are more peripheral. The height difference shouldn't be too much of an annoyance.
I just got my GTX 570 through the door, and as an SLI setup is needed for 3 monitors & 2D/3D Surround...
I've added another one to the basket.
Palit GeForce GTX 570 1280MB GDDR5 PCI-Express Graphics Card
Mobo
Asus Rampage III Gene Intel X58
Now, I'm pretty sure everything should work. I'm going to have to take out my sound-card, but I have on-board available. A little worried about the heat since one of the fans is going to be slightly covered on the GPU.
Finally is it worth it?
Does any one have any experience with 2D Surround, SLI, Tri-Monitor setup.
Hows compatibility with games?
My 1st SLI setup
Have I missed anything?
Thanks.
ooo *edit*
Is 2D surround compatible with DX11?
Mobo
My 1st SLI setup
Thanks.
ooo *edit*
