nvidia 3d info/advice
30 Aug 2006
i have an acer 3d projector 3d ready nivida
i dont want to get seperate bluray players etc , how can i set up the pc and projector in different rooms to play my 3d blurays and using nvidias kit ?
Hi im using the 3D vision kit from nvidia and i dont think you can have it in a different room as the IR sensor needs to be in view of the glasses.
I guess you could use a wireless HDMI and wireless USB sender - a good wireless HDMI sender tho costs as much as a cheap projector tho some of them do USB as well as HDMI.
Could you use a HDMI over cat5e/cat6 extender? If you get one that is known to work with HDMI 1.4 then this is probably the cheapest option (but does involve cables).
