Nvidia 4090 cutting signal to monitor after inactivity?
13 Jan 2023
TALIN
Recently after a driver update, my card started going to sleep if it did not detect any mouse movement. I have never enabled such a thing, and all power/sleep option are off. I went back to an earlier driver and the issue has gone away. Any idea what could be causing this or how to solve it? Thanks.
If you did a clean install of drivers it will revert any settings you did in nvidia control panel, first place i'd check if you had done.
Already did. I only use default settings in NCP. I reset it regularly, when any issue arises, just in case, even though I know I've never changed anything.
Might be a driver related thing then in the new update, usually what happens when they fix one thing they break something else.
