Nvidia 480 upgrade to 770 dimensions?
28 Sep 2009
Hey guys
I'm looking at upgrading from a 480 to a 770, to be more specific probably this one. But currently I have very little breathing space between my 480 and the plugged in hard drives. So I'm just wondering if this card is much bigger than the 480?
I checked the specs on the nvidia site, whichs says both cards at 10.5 inches in length (so would be answering my own question here) but any advice as to whether the heatsinks or anything are bigger?
Thanks!
770's are no longer than the 480 and the windforce card you link is 2 slot job the same as a 480 and thus should fit.
But check the Manufacture's website for absolute dimensions .
Perfect.
Looks like the absolute dimensions are: L=292mm W=129mm H=43mm (in case anyone else needed these).
Thanks!
