Nvidia 528.02 Resolution Issue
9 Apr 2007
Just updated to 528.02 and it's wrecked my pc, windows only sees my monitor as a Generic Display, limiting me to 1024x768.
It's an Aorus FI27Q.
Everything was fine before updating.
2560x1440p at 165hz.
I've tried going back to 527.56 and that hasn't worked.
Not sure what else to try short of a full clean install of everything.
See this:
Try going back to 517.xx
See this:
Cheers will give that a try.
Is there any good way of totally removing the old ones, or is the clean install option usually sufficient.
Not the same issue.
Ah cool, sorry, my memory of it is a bit vague due to me fixing it quickly. It was Throwaway's comment showing display port but didn't see it was specifically for your monitor, my bad.
Glad you're back up and running as normal.
